I've been lurking out here for years and following the general tenets of keeping my water clean. However, after a couple of weeks, it gets cloudy then green, despite the addition of more and more bleach. The chemistry is fine, at least until things get really funky.
Over time, I realized I needed to clean the filter more often to stay on top of this. But, I'm still puzzled what is going on. I don't have any drop in pressure. I don't have a lot of gunk (other than algae) in the filter. I usually go in later in the day and don't need sunscreen because of some shade from a hillside.
At first, I thought it might be all the trees (spruce and deciduous) in the vicinity. Just pollen build up or whatever. However, last year we took a few trees down and it is much more open around the pool. Admittedly, it seems to have helped, but the problem still occurs in something under a month.
It almost seems like the problem is emanating from the filter. It (and the water in the chamber) are considerably greener than the pool itself. In fact, I don't really let the pool get green at this point.
I haven't done anything extraordinary to clean the filters other than a good spraying. I assume a better cleaning would help, but I'd think the chlorine in the pool would kill any algae in the filter and that wouldn't be an issue.
The pool is a 21' above ground pool. No sand or salt or anything. Just plain-jane filtering. Chlorine comes from bleach. The CYA is usually about 30 but I adjust the chlorine level to match the current CYA per the tables on this site. The TA is around 90 and PH is 7.4. When it works, it works great. But, at some point, it just gives up...
Any thoughts would be appreciated.
thanks,
sf
thanks,
sf
