Dear experts, I have a fairly new 5600 gal plaster spool with IC20 SCG. I recently purchased TF-100 kit to manage my own water and here are my numbers:
Free chlorine: 4 ppm
Total chlorine: 5 ppm
Calcium hardness: 700 ppm (tested fill water supply and it is 50 ppm)
TA: 130
CYA: 60
Salt: 4000
pH: 7.8
CSI: 0.74
I know I need to drain some water and fresh fill to reduce CH and Salt (pool math says about 40% drain for calcium and about 15% drain for salt). I also know I need to add some more acid to reduce pH and TA. Is there a particular sequence I should follow to most efficiently/effectively optimize my numbers? Thanks in advance for any assistance.
TA: 130
CYA: 60
Salt: 4000
pH: 7.8
CSI: 0.74
