I live in Southern California, and my Calcium levels are up to 550 in my 15k gal salt water pool. I've been having problems with calcium flaking off my SWG, and scale around the tiles at water level. I have a couple of options:
1. Drain totally and fill with tap water (~30 ppm Ca here, but high in carbonates)
2. Partially draining, and refilling with tap water to bring the Ca down to ~200 ppm
3. Same as #2 but refilling with softened (ion exchange) water
4. Using one of these services that brings a truck by to "restore" the water by pumping it back through RO membranes.
#1 is very expensive where I live because we are in a partial drought and water is expensive.
#2 would be a cheaper way to go, but would I just be punting the problem for a year or two?
#3 seems the most attractive to me, as I have a whole-house RO system, and salt is cheap. I've read concerns in these forums about high sodium levels with ion-exchange water, but do I need to be concerned with a salt water pool?
#4 seems like snake oil, but I know it is popular around here. Apparently the pump trailer stays in your driveway for 24-48 hrs., and the service runs about $1K for a pool my size.
All suggestion welcome, and thanks in advance.
