Recent water readings
Ricker
Active member
Jun 2, 2021
36
Toronto
FC 4.05
TC 4.05
pH 7.6
Alkalinity 94
Adjusted Alkalinity 81
Calcium Hardness 273
CYA 44
Phosphate 129
So , my pool store recommends my Alkalinity between 100-120. Other sources, have a similar recommended range. However, according to TFP my level is just fine. Why such the discrepancy in recommended levels? And do I go by adjusted or just alkalinity?
Also, my pool store recommended range for calcium is 175-225. Is my calcium too high?
Did you get your own test kit? We will not provide guidance based on pool store tests.
Recommended Levels
You have a vinyl liner. Your CH is fine.
