- Jun 7, 2017
- 9,266
- Plaster
- Jandy Aquapure 1400
Check with your utility for rebates on those VSP pumps. Mine gave $400 for the Jandy 2.7hp VSP.
Just my 3 cents- swg can be installed, 1. I see a couple hours or “nuisance” & changing the plane of return manifolds, but a clean bets practice retrofit is achievable, without moving the risers in pad.
2. I have been putting small cartridge filters on water features lately, particularly in certain neighborhoods inundated with pine trees etc.. this is an elective practice.
3. Tough call on the “sweeps” they do look like Jandy branded schedule 40 sweeps- but as Mas said they do have a “Dwv” look. Look for the embossed specs on them or depth of solvent socket.
Anything can be retrofit on your pad with best practices & warranty compliance.. it just takes time, money & a sawzall. (Just at quick glance I see a handful of ways to salt & solar that equipment area). So long story short, if it wasn’t in the scope of work, don’t sweat it too hard, you will get it eventually..
as far as PB suggesting a third party , that’s bizarre to me - those are easy money sales.
Gotcha - I missed that part. At 2k rebate, he is leaving a thousand & a few Benjamins on the table - still doesn’t compute with me.
but since he is offering to make you whole via rebate , just move on & swim.
Color of pipe is typically material construction and not the schedule. White is pvc, black is abs, grey is pvc but generally for electrical conduit. His supplier might be different like that.
What you need to do is take a tape measure and measure the glue joint on the sweeps and compare that to the glue joint on the 45's and the valves. Dwv is 50-75% length of a glue joint.
