Closer every day. There is only a very minor clarity issue at this point, and all of the dead algae "piles" seem to have been mostly sucked up into the filter. So close!
Keeping with the CYA of 50. FC was 17. Added 10% liquid chlorine to bring it up to 20 per SLAM guidelines.
No real questions other than, the PoolMath app says that if I have CYA at 50, then my chlorine level needs to be between 4 and 8. That doesn't leave much room for actually keeping it at lower levels, right? Should I drain/fill my pool by 1/4 again to get the CYA more in the mid 30s or 40ish, so that I can run lower chlorine levels?
