- Jul 4, 2012
- 801
- Vinyl
- CircuPool RJ-60 Plus
I've thought about adding borates for the past 5 years or so, and now, since I finally got an SWCG last year, I need something fun to do with my chemistry.
Pool math says I need 50 lbs of boric acid to get my borates to 50ppm so plan to order from Duda Diesel.
The adding borates article says I should first lower my TA to the low end of acceptable range, but how necessary is that? My TA has always been high at 110-120 but Ph had been remarkably stable and tends to stick around 7.4-7.6. Even when I add cya to start the season, my Ph will decline a bit initially then just go right back to its happy place. I've been a tfper for 10+ years now and have deliberately adjusted Ph maybe 5 times, and probably once in the last 3 years because my Ph just self corrects if something causes it to get to the high or low 7s. Given the stability of my Ph I've never bothered to adjust my TA, ever.
With that fact pattern, is it still necessary or a good idea to adjust my TA down before adding borates? What are potential consequences if I just leave it as us?
Thx
Paul
Thx
Paul
