- Jul 21, 2013
- 66,007
- Plaster
- Pentair Intellichlor IC-60
It is setup to allow sufficient flow even when the UG is closed.Couldn't that be too hot and cause damage?
If things get too hot due to low water flow the 130F and 135F safeties in the manifold will shut down the heater.
So the UG handles cold water and the safety switches handle high water temperatures to keep the water in the heater within the desired temperature.
