Raypak Avia Low Flow Error
Nealkaiser
Active member
Jun 12, 2020
30
Lynn, MA
Hi, I have a Raypak Avia (only 2 seasons old) and I got a “low flow fault” warning about two minutes into heating. It still seems to heat fine and the flow in my pool seems normal, filter is clean, etc. any suggestions on what to check? Is it safe to heat with this warning? I tried to remove this to see if there’s some cleaning that needs to be done there, but couldn’t remove it. But I may be completely off track. Thanks for your advice!image.jpg
is the heater still under warranty?
The Aviva heater has had teething problems as a new design. Have you contacted Raypak Support and discussed your problems with them?
