I have a brand new Raypak heater 406a
It worked fine for 3 months approximately
It was erroring and shutting off with a high limit 2 error and was whistling at the heater loudly. They replaced the governor and it partially fixed it. Now it still errors but takes a couple errors . Also significantly reduced heat comming out of jets. I have replaced a 1HP hayward superpump ii With a hayward Tristar vs 900. Lowest speed I can run is 2950 where I don’t get whistling but this puts the pressure at the sand filter at 20
It definitely wasn’t that high with the original pump and before the issue occurred
I think there is something affecting heating and maybe even the heating or back pressure coming out of the heater?
The pressure coming out of the jets also seem reduced not sure if that my imagination
But the heat is at least half coming out of the jets
The warranty guy is coming out Friday again
Any recommendations/ suggestions?
- kevin
- kevin
