I removed the inlet/outlet polymer header on a Raypak 406A heater to inspect the heat exchanger.... I ordered a new gasket but the instructions aren't clear to me when it describes the tightening pattern. I think I know how I want/need to bolt it back. My thinking is do the center top and bottom, then do a row top and bottom next to it, then do a top and bottom of the row to the other side of the center first row...and keep working from the center towards the two ends so this way it can spread itself out evenly. The document that came along with the new gasket is not clear enough what they want you to do.
