- Jun 2, 2021
- 17
- Vinyl
- CircuPool SJ-40
Followed the instructions word for wordTA test never has purple color. Did you use the right reagents?
Total Alkalinity
A drop-based test used to measure the alkalinity in water. Alkalinity helps serve as a … Read more…www.troublefreepool.com
I'll go do another test and report back, about 1/2 hour"Sometimes a static electric charge can build up on the R-0009 dropper bottle tip, causing the drops to be smaller than usual and making the test read higher than actual. You can prevent this by wiping the tip of the dropper bottle with a damp cloth or tissue before you start and after each drop."
Total Alkalinity
I had already added the amount of borax (per pool math), Just checked my ph 8.7, trying to get this dialed in so I can start the Baquacil conversionAt a TA of 120, a pH of 6.6 will not be there long. I would not chemically do anything. Some aeration and the pH will be in the upper 7's quickly.
