Raising ph with air
May 5, 2017
13
South Bend/IN
Y’all prolly have a billion posts on using air to outgas the carbon dioxide and raise ph. I have set up a makeshift waterfall - wonder if this will work. Using a sump pump to pump water about 9ft in the air and drop back into the pool ... is this effective ? I’ve already dumped 2 gal of acid in the pool to bring the alkalinity down from 280 to 200 after one gallon, to 125 after the second - but my ph is now in the sixes.
There you go!
Sacha Baron Cohen Thumbs Up GIF by Amazon Prime Video
