Hi everyone. Our brand new raised spillway is great when it's running, but when the pump first turns on in the morning, it first struggles to flow over the spillway. The water rushes down the spa face instead of going over it. I found that if I push the water over the spillway in the morning, it starts flowing correctly. If I don't do this, the spillway struggles to correct itself on its own leaving water rushing down the face of the spa.
The pool builder is currently consulting with their team to come up with a fix, but at least acknowledge it's a problem since cleaning the filter did not do the trick. This is a brand new pool and the problem was recently discovered since pump went on a timer.
1) What could be causing this in your opinion...defective pump, poor granite install job that wasn't properly measured, something else?
2) Could this create bigger problems with the spa material or decking if this isn't fixed soon?
3) Can I turn the spa spillway off but keep pool circulating elsewhere until the spillway is fixed?
4) Any other suggestions?
Thanks in advance for your thoughts on the issue
