raised pool equipment 4" while pool was being replastered, now pump loosing prime?
Hello all,
I recently had my pool refinished (Pebbletec). The company did an outstanding job.
While the pool was being refinished I raised all the equipment (pump, filter and heater) about 4" as the pump would end up with water around the base when we received heavy rain.
Since refilling the pool every time I run the pump (twice now, just filled yesterday) I've had to prime it manually. It easily re-primes by filling the pump basked with a hose for just a few moments.
Is is possible that raising my pump a few inches is causing the system to lose prime? The pump appears to be just above water level, maybe a few inches higher.
My understanding is that in a perfect system once primed the system should stay primed unless a leak is occurring? Even if the pump is located above the water line of the pool?
I've searched (and will continue to search the forum) but haven't found my specific problem.
Hello all,
