- May 13, 2021
- 1
- Plaster
- Pentair Intellichlor IC-40
New pool owner here, got pool up and running last week. I noticed when Suction side is set to suction from pool and hot tub, when the pump turns off, the water in raised hot tub starts to drain out. Is this normal? Should there be a check valve in the pool suction to prevent the jacuzzi from draining back to pool?
I know water is trying to equalize itself, so water falls in jacuzzi to same level of pool.
Check valve need?
Quick Share
Check valve need?
Quick Share
