Hello,
My pool has been running about 2 weeks now and my water has always been sparkley clear. I received my test kit and pH test meter last night, up to now I have been testing with strips. As a result of the strip tests I have added muriatic acid several times. Now with the test meter I find my pH to be 6.2
This mornings results:
FC = 3.5
CC = 0.0
TA = 70
CH = 225
CYA = 0.0
pH = 6.2
1) Should I try to correct pH and CYA at the same time or should I tackle one of them 1st?
2) I have about 7 pounds of Trichlor tablets that I bought before discovering TFP, is it reasonable to use these to raise CYA? Home Depot has a 5 pound bag of stabilizer but I think I only need about 1-1/2 lbs to get to 30
3) Should I use borax to raise pH? Will it drift up naturally if I leave it alone?
Thanks for your help......Dennis
FC = 3.5
CC = 0.0
TA = 70
CH = 225
CYA = 0.0
pH = 6.2
