Thanks for updating the instructions. I also was wondering why you couldn't add BTB before adding R-0009 to visualize the yellow transition. The
proteam supreme test instructs the user to add more acid (R-0009) after adding BTB if it does not turn yellow, if I'm reading it correctly, so I assume that will work. I will try the updated instructions when I get to test.
If R-0009 = 0.437% MA and your test results: pH 7.8, TA 60, Borates ~50.
Your instruction says for 50ml sample use 8 drops of R-0009 which should drop your pH to 6.0, right on the transition of being yellow.
9 drops R-0009 drops pH to 5.9,
10 drops R-0009 drops pH to 5.8,
12 drops R-0009 drops pH to 5.7,
13 drops R-0009 drops pH to 5.6.
That is if all my calculations pan out, my drop rate is 20 drops per ml. Have you had any trouble testing sitting right at the yellow transition point of the BTB?
If all I do is change the TA level (still with 50ml sample):
TA 70: 9 drops of R-0009 to drop the pH to 6.0.
TA 80: 10 drops of R-0009 to drop the pH to 6.0.
TA 90: 11 drops of R-0009 to drop the pH to 6.0.
TA 100: 12 drops of R-0009 to drop the pH to 6.0.
Looks like the TA level could dramatically change how many drops of R-0009 one ends up using. Maybe your instruction should say use R-0009 until the straw color, then add a drop or two. That will eliminate the confusion of using 8 drops of R-0009 because you know someone with a TA of 80 or 90 will use 8 drops of R-0009, or even I would have with a TA of 70.
Also if I could suggest listing a recommended size of mannitol and BTB to buy and the shelf life of them. I received my 4 oz of mannitol today and the bottle is alot bigger than I thought is was going to be. I'm not sure how many tests it will actually do, but it looks like 3-4 years worth of borate tests.
