I'm trying to clear up my pool again and the water turned even more green overnight. I put in 1 gallon of chlorine last night, this morning, and 30 minutes before this test. I downloaded the app today and am a little confused by the recommendations. The calculator says the alkalinity is high but the kit says its in the middle of the range? It's also suggesting I add 23 gallons of chlorine to reach my 10 FC slam target which can't be right.
25,000 gallon pool
Test kit: Taylor K-2006
1 ppm free chlorine
2.5 ppm combined chlorine
7.6 ph
100ppm alkalinity
140ppm calcium hardness
Cya 10? too low to read. I'll be adding more CYA.
25,000 gallon pool
1 ppm free chlorine
7.6 ph
100ppm alkalinity
