Hi all, first time poster here. Our pool was completed about 3 months ago and I’ve been maintaining using liquid chlorine since startup. I’ve been slowly pouring half a gallon of 10% everyday at noon in this Houston weather, and am ready to make the switch to make maintenance less tedious. Unfortunately there wasn’t much room on the side of the house where the plumbing was installed and so the install looks like it’s going to be a little tight. I’m interested in the circupool rj60+, but wanted to check if I have enough room. I’m considering a vertical install where the inline chlorinated currently sits, or potentially installing horizontally in the plumbing run after the heater. Is there any reason that this won’t work?
