Hi! I have a big green monster. It's bad. I started SLAM yesterday. I have the pool math app and I'm trying to figure out how to load that info here (do I have to do it from my phone? I'm typing this on my computer because it's faster that way, lol).
Anyways, questions. Can I accurately measure CYA during slam? When I first did all my tests, my cya was low, so I used one bag of hth shock in addition to the liquid bleach hoping to bump that up just a tad. I've only used liquid bleach since - don't want to have to drain the pool down again if I can avoid it.
The SLAM instructions say to brush and vacuum at least once a day. I've been brushing more than that, mostly because I can't see what I'm brushing so I'm hoping that by doing it more frequently I'll actually get everywhere at least once or twice. The vacuuming, though - does that means manual vac? If so, to filter or waste? I have my dolphin (with the fine filter) running pretty much non stop through the day, rinsing the filter every couple hours.
I'm planning on picking up some pool grade de on Friday when I go to town to add to the filter, but nowhere nearby has it, so I'm out of luck until then.
Could've sworn I had one more question, but I've lost it. I'll post it if I remember.
Thanks!
~Smash
ETA: hopefully this is right
ETA #2 - I remember the other question! When doing the chlorine test, you have the pink water, then add the drops to get it clear again. I've noticed that I'll get it clear, but then if I leave it sitting for a minute, it's starts turning pink again. Do I need to wait for this to happen and continue adding drops, or is the count accurate the first time it goes clear?
Thanks!
~Smash
