I just bought a new puritech uniboost. My existing setup has the hard pipes with an inlet connection of .75 in size and outlet of 1.5in. size. It looks like the quick connections the new pump are size 1.5in. The current setup looks like the .75 in pipe connects to a 1.5 in. pipe via a reducer. I'm wondering if I could just remove that reducer, and fasten my quick connects directely to the 1.5in pipe.
One more question, for replacing the outlet connection via a hose, do i just use a pipe cutter to remove the entire hard pipe and use the quick connects on both ends as well?
