Hello,
Freshly filled pool that started on this past Sunday, so we’ve been up and running just the past few days!
I got my water tested at a local pool place on 7/2. Per their recommendation, that evening I added 2 cups of stabilizer into my skimmer basket. A few hours later I added 2 gallons of liquid chlorine. We had a pool party yesterday.
Today I went back to the pool store and was given this paper test result. This evening I added just under 19 oz of muriatic acid, and about 45 min later 2 gallons of liquid chlorine based off their recommendation.
Test Results before MA/LC addition:
FC .09
TC .09
CC 0
CYA 2
pH 8.1
TA 123
I have a few questions:
1. Does this sound like a good/correct regimen to follow so far? My pool seems ok but I should be receiving my Taylor K2006 tomorrow and can experiment myself. The guys at the store seem trustworthy but I was under the impression once my pool is balanced, I would be adding much smaller amounts of chlorine at a time on a frequent basis as opposed to gallons at a time? He seemed to imply that because were in AZ, it’s a ton of liquid chlorine regularly?
2. Where do you store your 31.5% muriatic acid? Where do you store a few gallons of 12.5% liquid chlorine? Where do you store powdered stabilizer? My options are laundry room, garage, a plastic deck box or storage shed outside in backyard.
3. As far as CYA granules, I put 2 cups slowly into the Embassy skimmer basket and I noticed it was gone very quickly but I saw some granules in the pump. I have ran my filter almost 24 hours a day since Thursday to circulate the chemical and employee told me it would take 6-8 days from 7/2 to see the “true impact” of the 2 cups of CYA. The level was 1 on Thursday and today he said it was 2. Is it really going to spike up a noticeable amount in the next few days or did I do something wrong? Don’t want to overdo the CYA but did I do enough?
Obviously I can test myself soon (once I learn how to use it lol) and get the results of what I actually did to my pool tonight, but I am wondering if the current track I’m taking seems accurate and safe.
Thanks for any advice and thanks for reading my lengthy post if you did.
FC .09
TC .09
CC 0
CYA 2
pH 8.1
TA 123
