- May 20, 2021
- 45
- Vinyl
- CircuPool RJ-45
So I have installed the SWG and new variable speed pump.
I have a 32000 gallon water
SJ 45 SWG
I have Hayward 27 inch d and filter with 1.5 valve.
I plumbed two inch out of pump converted to 1.5 at filter head.
Out put to SWG is all 1.5 inch thru out to water from filter thru flo meter and cell. Then splits into two pipes into pool. Seems to run ok but lots of air in SWG not making chlorine yet.
Questions
Is this ok or should I change 1.5 through out or replace head unit on filter to 2 inch and run 2 inch thru out.
Have SWG invited as manual says with VS pump to install upside down, is installed horizontally. Is that correct?
Thanks
SJ 45 SWG
Questions
Thanks
