Is there a "normal" pressure for a sand filter?
I've been SLAMing for a week, with no improvement to green water. Visibility is approx 3.5 feet.
After backwashing, my pressure is 10-12 psi and flow out the returns seems good. If I take in water only from one skimmer and a vacuum port located half way up a wall, the pressure never increases, as if the filter is not doing any cleaning . If I vacuum the bottom, the pressure increases in just a couple minutes, and flow out the returns all but stops. When I backwash for 2 min, followed by 30 sec rinse, a stream of "dirt" comes out the return lines for about a min.
I've vacuumed the bottom to waste best I can (without being able to see the bottom). I've checked in the past for channeling, but don't see any obvious signs of that.
Beginning to wonder if the pump isn't putting out enough pressure to properly circulate water through the system.
