I just purchased the Taylor 2006. This is all new to me. I am a little confused on the PH and TA. Below are my results. I am not sure if i should bring up my PH first or work on lowering TA
FC - 1 I believe I need to add some bleach
PH - 7.0
TA - 160 - I just purchased some muratic acid
CH - 270
CY Acid - 30
We have a pump in the pool right now with a hose to aerate the pool but not sure if its enough. I am afraid the muratic acid will really reduce the the PH down too much.
Not sure if my info comes across - Intex 18x48 above ground salt water pool, sand filter.
Thank you!!
PH - 7.0
CH - 270
CY Acid - 30
Thank you!!
