From a quick look at the install of my heater, it needs to be replaced do to age and AZ heat it is full of leak. If I need to replace Im thinking it might be a good time to
re-plumb things and fix some stuff if possible.
The drawing below is what I have for the heater, there is 1 control valve installed and if I'm using the heater close this valve and force all the water thru the heater. Under normal pool operations this valve is mostly open but not fully to allow little flow thru the heater just to keep water moving thru it. (I do not know that is what I was told) however, I have no idea if or how much water is infact moving thru the heater. To me this just seems like a cheap way to install, is it ?
I was thinking I could change a little bit add 2caddition valves and have more control but would this make a difference ?
What would the best options be? Someone said to look into 3-way valves but Im not sure what that would look like or do?
Adding in 3-way valves ?
