I have a question in regards to the [FC/CYA]Chlorine/CYA Chart[/FC/CYA] when using a SWG during colder months when water temperatures are too low.
According to the chart, one should keep the CYA levels a little higher (70-80 range) when using a SWG along with being able to use lower chlorine levels. What levels should I be using when the pool is colder and the SWG isn't producing chlorine? Should I bring the CYA down to the 30-60 range since I am manually adding chlorine.
I'm sure the answer is just keep the numbers in the SWG range, but I haven't seen this addressed and want to make sure.
Have the same question in regards to the CH but wanted to focus on the CYA/FC levels first.
Thanks.
Thanks.
