Hi All!
We went through a huge renovation of our Gunite pool last year and are thrilled with the results and so, have stayed with our pool company. But, I recently found out that a friend is paying about 1/2 the cost we are monthly, for pool services. Our finish is quartz, hers is plaster. I do not know if that makes a difference, but her pool company uses significantly less chemicals than ours does. Neither of our pools are saltwater.
Her last month looked like this:
- 5 Gallons Chlorine shock
- 12 lbs balance pak 100
While mine is usually some combination of significantly more chemicals- an example of a month last year:
- 35 lb sodium bicarbonate
- 7lb muriatic acid
- 1.5 lbs liquid shock
- 22 3” chlorine tablets
- 25 lb granulated chlorine
- 5 lb diatomaceous earth filter powder
Her service is $430/month, including cleanings ($65/week vs my $85/week). The bill for what was listed above plus cleanings was almost $900. I’d love to save some money if I can but totally clueless if the different finishes are causing the completely different chemical plan. Any insight would be appreciated! Thank you!
- 7lb muriatic acid
