Questions for you guys. I learned something new every year and this forum has been a great resource.
So I have 15 foot Intex above ground pool with the 2800 series Intex sand filter and I just use the basic Intex skimmer basket that hangs over the side of the railing.
Yes, one day I intend on getting the Hayward skimmer that goes in the side of the pool, but I haven’t done it yet because quite honestly I don’t trust myself to cut a hole in the side of the pool and not end up with leaks lol but that’s another story LOL!!
My question today is when I plug off one of the inlet ports so that the skimmer gets better suction, my pump becomes markedly louder because of the air being sucked in. I have tried using a plug that had the little tiny hole in it to let minimal water through and I have also tried using a plug that was solid to just close it off and I have the same issue. If I have both ports open, the pump is so quiet I forget it’s running and it’s beautiful. But then, of course I get no suction at the skimmer and its effectively not doing its job
So my question.. is this normal? I feel like it isn’t because I can see the air bubbles going through the line and it does cause the pipe to pulse occasionally. And I know that’s not good for the motor.
So what is the trick? Do you guys just bypass that one inlet all together and run one hose straight from the pump to the skimmer port? I currently have it teed off to where one hose is going to each port and then converging in the third hose that goes to the pump.
