On my 3rd water fill in my 410 gallon Tub. TA in our city water is nearly 400 out of the hose which requires a lot of acid to bring it down. My process is to add 1-3oz every 10 minutes or so with jets on until it gets to 40-60 and Ph is at 7.4-7.6 stable. This takes forever. Per my calculations it took around 28oz. Would there be an issue to start with a bigger does of say 10-14oz and then work my way up there to save some time or is that risky?
Also, I am still learning the technique when doing the drop test, but what I experienced last night made me question what my actual PPM was at. When I got to the 4th drop (40PPM) the solution was very pink. However, I added a 5th drop just to be sure and it got even Brighter pink? Would that mean I am some place between 40-50 or at 50? Or even at 40 because it was very pink at that point?
Thank you all for all the help thus far!
