Hello, I’ve done a fair amount of reading on these forums regarding how main drain flow can be controlled by skimmer diverters (assuming the pool was plumbed for it). However, there is one part that I am still not understanding.
From what I’ve read, it seems that when the diverter in the skimmer is open, the pump will pull from the skimmers and not the main drain since that is the path of least resistance. Then when the diverter in the skimmer is closed, the pump can no longer pull water through the skimmer so it pulls from the main drain instead.
If that sounds about right, can anyone explain what the second hole at the bottom of the skimmer is for? People have said that it goes down to the main drain but I am not understanding why that is necessary. Thank you!
