Hi All, this will be an odd question, but I take really good care of my pool and help others do as well. In preparation for closing today, I was running my filter pump 24 hours a day with the skimmer drains open, and the floor drains closed (the goal was to capture all the leaves that are falling in the skimmer baskets.
I use a pool company to close. They had to cut there day short as it is really cold and rainy. They use their own pump to drain the water down below the return lines. They had to cut their work short this afternoon due to very cold and rainy weather. I went to check on things, and saw that they left the filter pump running and the floor drain valve was still closed, with the skimmer valve open. The pump basket was dry (because the water was below the skimmers) and the pump was running. I immediately opened the floor drain and the pump basket filled with water.
The pump probably ran dry for 3-5 hours.
My question:
Do you think I have anything to worry about it terms of damage to the pump, heater, or anything else?
Thanks!
My question:
Thanks!
