- May 19, 2022
- 115
- Plaster
- Pentair Intellichlor IC-40
Hello TFP!! I’m back again with more questions.
I brought my TA down from 110 to 90 with MA which pulled down my pH to 7.2. I do have a sheer descent which would help with aeration to raise pH but I do not turn that thing on because the last time I did I lost 2 inches of water in 45 minutes! That’s another problem for another day.
So, cut to me buying this 0.5 HP submersible pump. How often should I measure pH level to check progress? How long would you anticipate it needing to run? Current FC is between 8-9ppm.
Picture attached of how much air my water stream is getting.
Thanks!
Thanks!
