I read some of the posts about using borate for raising pH rather than sodium carbonate and I was wondering how many people actually do this? My understanding is that the amounts of borate added when adjusting pH are much, much lower than adding borates for buffering, algae retardation, and water feel--so although not many people do the latter, there might be quite a few doing the former. If I understand correctly, borates also don't "go away" unless the pool is emptied. However, one of the posts mentions you have 50 ppm borates in the spring, it will decrease to 30 ppm come fall--is this due to splashing out, etc, or is there some other process I don't understand? I just want to make sure I'm not putting myself into a similar situation as our current situation with cyanuric acid from the previous owner (over 150 ppm, yikes).
