Hi there,
On Thursday a new quartz aggregate pool plaster (ColorScapes by NPT) was installed and the start-up was initiated by the PB (who had subcontracted the plastering) yesterday morning (took some time to fill). The plaster subcontractor gave him a sheet saying on step 9 (see attached) “Maintain ph level at 6.8 to prevent scaling”. This seems to be much lower than suggested elsewhere (New Quartz Plaster Startup Procedure - Revisited) and also by NPT (which recommend the NPC start-up).
Should I tell the PB to not follow those instructions? Are there any issues with the other instructions? He will come for another 3 days and then I am on my own.
The PB also through 4 chlorine tablets in the skimmer and activated the Polaris pressure driven pool cleaner. I read that the former will cause corrosion in equipment (“PB it’s no problem”. He bypassed the heater) and on the latter even NPT says “wheeled devices should not be used in the pool until after 28 days.”. I read somewhere that quartz is harder and a cleaner can be used after 3 days.
I am really concerned that some shortcuts are taken for convenience in the short term which affect the long term durability.
As usual thanks in advance.
