I had my '95 Hot Spring Grandee drained over the summer, just gave it a cleaning and filled it up for the fall and winter. After filling, I flipped the 20W breaker on to fire up the circ pump. After circulating for awhile I noticed there was an air bubble in the hose between the circ pump and the heater. I moved the circ pump up and down and got the air pocket to move on. When I was doing that, I saw air bubbles come out the discharge end of the heater so I thought I had successfully purged the heater of air.
When I finally flipped the 30W breaker for the heater, I heard the heater come on and the sound of steam and then a good sized air bubble came out of the discharge end of heater and went on up the line towards the flow sensor. I guess I didn't have it completely purged of air after all. When the bubble hit the flow sensor, the tub shut down like it's supposed to. I flipped both breakers off, let the tub sit with no power to it for a couple minutes to reset everything and then started up normally again. Now everything is working perfectly except the heater. I have the control box open and I measure 240 VAC on the output side of the heater relay and I've done a bunch of other testing so I know the relay is working properly and because the relay is closing to send the heater 240V AC, I know the thermistor is calling for heat and I know the flow control switch is working and registering flow because the relay would not close and the heater would not be getting 240V if either of those things were not true.
So it would seem the heater has failed but when I measure resistance through the hot leads going to the heater I get 11 ohms which is what you'd expect for a healthy, intact heater element. I would think that if the heater element fried because of the air pocket, I would get an open circuit when checking resistance through the element. So from that I'd say the heater element is okay but I know the heater is getting voltage and yet the element is not heating up. I am perplexed. Am I wrong about what I should be reading for resistance through the element when it's good vs when it's fried?
I am using the new 6KW Watkins No-fault double tube low-flow heater made by Hydroquip. It does not have a reset button on it.
