I have a fiberglass inground pool, 7m x 3.5m (23ft x 11.5ft), 25000 liters (6600 US gallons). On starting up for the summer the pH was very low, so I over a few days I added a few kilos (several pounds) of Soda Ash (sodium carbonate) to raise the pH to the correct range. A few days later, purple deposits started appearing on the sides and bottom of the pool, which increased over following days. The purple material is has a fine, slightly gritty texture, and while the excess material vacuums off, some of the material sticks to the surface. Brushing removes it partially, but there still remains a purple'ish residue, and I have to clean the pool every few days.
For my Chlorine I use multi-action tablets (pucks?) which are based on Tri-chlor. The water is perfectly clear. I am located in Cyprus (East Med), and the day temperature is currently 30-33C (86-91F).
Any advice please on what is the cause of this and how to get rid of it? Thanks
