Pureline SWG Life
Jan 11, 2019
9
Tallahassee, FL
I have a PL7703, which is a 60k gallon SWG I bought from INYO in Nov. of 2019. Pool is around 25k. I keep as close to perfect water chemistry as possible and have never had to clean my cell, looks like new, no scale at all.
I am now having to run my cell for 19 hours at 85% to keep 5-6% FC, this is also while maintaining CYA at 60-70. Last year I was closer to 14 hours summer at 75% output. Is this cell running out of life being a generic? It is extremely hot if N FL right now. I do run the cell 24/7/365, obvoiusly much lower in winter, like less than 10% for around 8 hours. Thoughts?
What is your salt level?
How do you test your salt level?
Is your salt level different now then last year?
Do an OCLT to verify there is no algae (pump/SWG off). Raise the CYA by 10 and see how it does.
Salt level is at 3200. Test with Taylor salt kit and some strips I'm trying to get rid of I bought off Amazon, just as a way to double test.
Salt is inline with what I had last year.
OCLT is 0.
I've thought about performing a cleaning just to see what happens, even though it will take some life out of the cell.
I'm in a vinyl pool, so no calcium. I do use well water so that water is hard. Could there be some scaling from the hardness in the well water I just can't see on the cell?
You should only clean a SWG cell if it has visible scale on the plates.
First try and use strong blasts of water to remove the scale.
You can scrape the plates with a stick, like a Popsicle stick, to remove the scale.
If the scale is stubborn then use cleaning vinegar (6% acetic acid … available in Home Depot). It’s milder than Muriatic Acid and won’t damage the ruthenium surface. Highly concentrated mineral acids are not good for the transition metal catalysts.
Cleaning a SWG cell with Muriatic Acid 10:1 diluted solution will remove some of the rare earth coating from the plates and reduce the life of the cell with every cleaning.
How much production run time is on it? The cell is rated for 7000 hr. I also have a Purline 60K system that I bought in February 2019. I run mine for 15 hours at 40% and it keeps my 30k pool CL right where I target it. My cya is usually between 60 and 80. The cell has somewhere between 2000 and 2500 production hours on it. I have never cleaned it, but my CH is around 30 to 50 ppm.
I have the PL7704 (heavy duty model, 10,000 hours) also installed in 2019.
I run at about 50% for 12 hours in the summer, maybe 8/10 hours in spring/fall, for my 35,000 gal pool, salt at 3700, cya @ 70
FC kept at around 8/9, which is on high end
I have never had to clean mine.
The extra hot weather we are having could be effecting your FC usage.
You might be nearing the end of your cell running it 24/7
It makes no difference to the life of the cell if you run it 24/7.
The amount of chlorine generated affects the life of the cell.
Running at 10% for 24/7 uses the same amount of life as 50% for 5 hours or 100% for 2.4 hours.
Reactions: blazer58
My thinking was for three years running at 70% avg, he has used 4900 hours thus leaving app 2100 hours on his cell
am I figuring this wrong ?
Cells life vary widely. Some die prematurely and some live a long life.
Reactions: blazer58
No, I don't think you are wrong. The other day I did some calculations using the info that you included in your first post and came out with about 5500 hrs
Reactions: blazer58
