Re: Should I replace my pump with an IntelliFlo or a Max-Flo
Usually you would have to use high to fill the panels, then low should be able to keep water moving slowly.
The heat transfer is better at higher temperature differentials. Therefore you get more heat to the pool by heating a lot of water by a few degrees than very little water by a lot of degrees.
Usually any of the panels want around 1 to 1.5 gpm per 10 sqft of panel.
