The distance between the Jandy valve and the pump intake is way too small.
Turbulence is most likely doubling your electric bill and you may have cavitation as well. From the hydrodynamics course the longer the distance the better. ASPS recommends 4 x pipe diameter. Most pump manufacturers (including Hayward, Jandy and Pentair) recommends 5 x pipe diameter. It may not be easy to change in your install but it might be worth the effort.
