- May 3, 2007
- 16,964
- Plaster
- Hayward Aqua Rite (T-15)
0.635 meters of vacuum is 25 in hg. which is very close to cavitation which is why they specify that. There is very little chance that you will have that much vacuum but if it is a concern, you can purchase a vacuum gauge and measure the vacuum at the pump.
Exactly how did you calculate your head loss? Your numbers do not make sense. An Intelliflo will never reach run out on a typical setup so 160 GPM is not possible.
