You need a gas powered trash pump or something similar to move that much water. Also, consider where you can discharge the water as that high of rate will tear up any ground you hit it with and it’s unlikely a residential sewer clear out port can handle that much flow. If you have a swale or wash nearby, that’s the best place to send the water.
If you have to use a sewer line then you’ll need a slower pump, 1HP or so as
@mknauss suggest. My 3/4HP submersible can lift water 7ft and run it out over 100’ distance at a rate of ~ 23 GPM or about 1400 gallons per hour. I did construct some 1” PVC piping with unions to attach to the pump and give it a straight lift up before attaching it to a 1-1/2” discharge hose. Larger diameters would have given me higher flow rates but I don’t need higher flow and 1” PVC is easy to work with and store.
