PUMP STOPPED PRIMING OUT OF NO WHERE
ahha0527
In The Industry
Jul 11, 2022
45
Los Angeles
Jandy epump is 10 plus years old
everythin has been working perfectly but randomly stopped priming out of no where
filled pump with water , checked for air leaks , o ring..valves have been untouched with skimmer side open…used cobra rubber bladder through skimmer as well to push water through and nothinhg
pool is clean with cover on with zero debris ro have caused a clog
can it possibly be the pump is giving out and needs replacement?
What type of filter? If cartridge or DE, remove the elements and try. A very clogged filter will not allow a pump to prime. If sand, put the MPV in the recirc position.
