Our pool/spa was mostly completed last November, then closed for winter, and re-opened about 2 weeks ago. I'm pretty confident in my ability to perform the chemical tests (now that I have my handy-dandy TF-100 Pro with Salt... with Smart Stir, which could be called "the marriage saver"
). I've used liquid chlorine until yesterday, when we finally got our SWCG properly connected, so I started adding salt to switch over to the salt method.
Along with getting our SWCG up and running, the Hayward expert got us going on the OmniLogic app. That change-over now has our pump programmed to run at Low (50%), Medium (85%) or High (100%). I believe the max is 3450 rpm, so 50% would be 1725 rpm, correct? He left it running on a 91% schedule from 6AM-9PM, which seems kinda excessive to me, but as a newbie, what do I know?
I know we can customize things, so I'm looking for advice as to the best pump speeds and run times (schedules), aiming for efficiency between water clarity/chlorine generation and not wasting electricity/$$$. For example, how do I know how low I can run the pump and still have the SWCG function properly?
I believe I have my test logs linked. I plan to test the salt levels later today before adding more so as not to over-do it!
