- Apr 10, 2018
- 6,412
- Plaster
- CircuPool RJ-45 Plus
Looks like spring will finally be arriving this week after unseasonably cold and rainy weather. Temps will be rising about 25 degrees from the 60s to lower 90s in just a couple days. I want to heat up the pool to so we can kick off our Covidcation.
Does pump speed have any effect on the heating speed and efficiency?
I thought I saw a recent thread indicating a higher speed was more efficient. With a balance of solar generation credit, I'm not worried about electrical costs. With a VS, my lower pump speed is1600 1800 rpm and higher speed is 2500 rpm.
I found a Pool Heater Time Calculator online that indicates I can increase water temp of 18,500 gallons from 65 to 85 degrees in about 6 hours with a 400K BTU heater and solar cover. Does this seem accurate?
