I have a main pump running my pool today but it does not have enough power to run my pump and all items like in floor cleaner as well as the waterfall and deck jets at once. I have access to a Pentair Superflo 2 HP pump. Would that work to power the waterfall and deck jets? Should I go that route with a second pump or stick with a single pump and try to change the flow from the in floor cleaner to the water features? So two questions...
1. Am I better using two pumps or one?
2. If two pumps is better, is a SuperFlo 2HP too big (2 in pipe being used if that helps)?
3. If a singly pump is used how would I set it up with my Pentair EasyTouch so I could turn on a feature and get the valve actuator to turn?
Thanks for the help on this. Just trying to find the most sensible route to go.
