- Dec 28, 2022
- 48
- Plaster
- Pentair Intellichlor IC-60
Morning. Yesterday I had a new Intelliflo 3hp pump installed and two IC60's. My question revolves around the pump speed. Since we dumped a 1,000 lbs of salt in the pool yesterday the pool company asked me to run the pump all night before turning on the SWGs and running the rpm faster than needed. After slowing the pump down I noticed that to get the flaps in the skimmer boxes (SB) to lay down with a bit of water over them I had to set the rpm at 2,200 with the main drain/SB valve choked a tad bit towards the SB. I would certainly like to run the pump slower and I could continue to choke the valve to send more water to the SBs but that would certainly reduce the volume turnover in the deep end of the pool. I've read several running their pumps slower in the past and it just seems a little odd that I have to run the pump so high. Maybe not. What do you guys think?
