Hello All - My primary pump started to make a high-pitched noise a couple of days ago so I think it's on its last legs. It's 8 years old, and is making the noise whenever it is running. The pump is a Hayward Tristar Power End 2HP 2-Speed, model #SPX3215X20Z2PE. I'm considering doing this myself - I have not replaced this primary pump via DIY, but I have DIY-replaced a smaller pump that runs the waterfall and the booster pump. I'm also not sure if I should just get the same pump or upgrade to another pump - for example I've seen some other threads suggesting pumps like the Intelliflo 11056, but am not sure if an upgrage the right way to go. The current pump has done its job well and the Intelliflo pumps appear to be ~$1,000 more expensive than the Hayward model that I have now. I'd appreciate any guidance on the following - Thanks!
Should I upgrade or stick with a replacement using the same model? Pros and cons would be helpful here.
Are there any issues that I should be aware of if I try to DIY this pump, as compared to having replaced a smaller pump and booster pump?
Would it make sense for me to replace the motor in the current pump rather than installing a completely new pump?
