Hi! Preface: I am a pool owner I don’t know much about schematics of how a pump works. I noticed yesterday my pump was on, but it didn’t look like the water was bubbling in the pool like it normally does when it’s on. I thought maybe it was due to how full the pool was. I meant to go check it, but forgot when I went to work. This morning when it turned on I went to go check the pump and I noticed it was on, but no water was coming through. I went and turned it off then went to remove the basket to check if anything was blocking it (nothing I could see). I turned it back on with the basket removed and after a little bit it started sucking the water through. It seems to be working fine now. But I’m not sure how many days it’s been on and not pulling any water in. Is it likely there is damage I can not see? I wasn't sure if I should keep running it after that happened. Any advice is greatly appreciated. Thank you!
